Is there any way this doesn't cost a boat ton of money to fix?
Thanks for the advice, fortunately, I have several shops within a 1/4 mile of me so I will start calling around. I would be able to grind it off/drill it out, but I do not have any welding experience.Mike W. wrote: ↑Sun Nov 16, 2025 12:19 amPlease, don't try to drive it like that. You'll just f'up the new shock.
So, since you have at least some access from the back, you have a variety of options.
Take it to a shop. Yeah, probably not cheap, but occasionally it is.
Take a piece of water pipe, work the remaining stud back and forth to snap it off and drill it out.
Grind/drill it out from the back, not sure what the access is, but if you can at least take a pic of it you have some. Ideally you might want it welded back in place after you slip a new bolt in place.
Not good, but not the end of the world. Take it into a shop, not dealer, it's just basic mechanical, doesn't even have to be a Nissan shop, with pics and ask them. If they say 2 hours for diagnostics and we'll go from there, run away. If they say sure, we can do that, well, probably go for it.
Got it, so cut the old shaft off up to the flared out part and have the new bolt welded there? Will that have the strength it needs? It seems like this solution would be best so the rest of the stud can remain where it was from the factory.VStar650CL wrote: ↑Sun Nov 16, 2025 9:08 amMcMaster-Carr sells metric shoulder screws with shoulder diameters up to 20mm and lengths up to 150mm. Measure both, find a screw that matches, cut the old shaft off, and have a welder replace it. If the thread diameter or pitch doesn't match, who cares, you'll just have two different size nuts. The shoulder dimensions are all that matter.
https://www.mcmaster.com/products/shoul ... -screws~~/
Correct. Have a good welder secure it with an electric pipe weld all the way around the circumference, it will be plenty strong. Those studs never bear the whole weight of the vehicle or see any direct impact, so the stud doesn't need the strength of, say, a ball joint. Just a high-quality weld with good penetration.
I found a great welder and he was able to keep the bolt intact and get a threaded piece welded on to secure the shock.VStar650CL wrote: ↑Sun Nov 16, 2025 1:25 pmCorrect. Have a good welder secure it with an electric pipe weld all the way around the circumference, it will be plenty strong. Those studs never bear the whole weight of the vehicle or see any direct impact, so the stud doesn't need the strength of, say, a ball joint. Just a high-quality weld with good penetration.
