Screw size for gauge cluster?
Pianodemon
Car: 1998 Nissan Pathfinder LE
I took apart my dash to put blue LEDs behind the gauge cluster (looks REALLY sharp, thanks for the instructions, all) and in doing so, managed to lose a couple of the screws that connect the gauge cluster to the frame.
Any idea where I can get replacement screws or what size they are?
If worse comes to worse, I can head to a pick and pull this weekend and see what they have.
Pwnin O'Brien
If you have one of the screws then you could probably take it to a Lowes or Home Depot and just buy the matching screws. If you don't have any of the screws then you could always pick some up from the dealer. The following link is to the actual replacement screws for the cluster from CourtesyParts.
http://www.courtesyparts.com/2....html
Pianodemon
Thanks for the help, Pwnin. Much appreciated.
