screw IN my vacuum line.. not impressed
CanuckQx4
Car: 2001.5 Infiniti QX4 2WD
I was slightly bored today and thought my engine cover needed a good cleaning so I removed it and as soon as I popped it off at the front of the engine I saw this
Without my baby fingers
Literally a screw right into a vacuum line coming from the engine at the very front drivers side. It was even leaking as when I pulled the screw out and capped it with my finger the engine idled a little better.
So my question is where is it supposed to run to? I dont see any open male ends and it looks like the line was cut and capped and tucked under the cover
:gotme
Pwnin O'Brien
Can you get a pic farther from the bay so we can see the vacuum line in relation the the engine? It looks like it could be the line that's supposed to go to the swirl valve actuator, but I can't be too sure.
miamiheat3332
Car: 2002 Nissan Pathfinder SE - 2006 BMW X5 4.8is - 2001 Audi A4 1.8T Quattro Sport
Yeah take a picture a bit farther from the engine bay with an arrow or something showing the location of this, i was going to go check, but i dont know exactly where that is, im thinking right in front when you take off the 3.5 cover.
CanuckQx4
Ya its right at the front of the engine closer to the drivers side
Its not the swirl valve vacum line, you can see in my pic the vacum line for the swirl valvew, about 1" below the one Im pointing at, running the same direction if that helps
My girls out at a christmas party and took the camera so I can get pics later if needed
CanuckQx4
Pwnin O'Brien
CanuckQx4 wrote:69
CanuckQx4
we call that being intoxicated on wednesday at a Christmas party lol
PEZi
i'm assuming a previous owner put this in there attempting to plug the line for something :gotme
CanuckQx4
I was hoping it was a line for my factory intake system or something.
The car came with a CAI (CUSTOM) so I dont know
I was browsing the fsm and couldnt find a good overall vacuum diagram, I suck at searching that damn document, they put things in spots I would never think to check lol, I need to learn more tech lingo
miamiheat3332
take a pic a bit more farther away and ill tell you exactly where it goes.
CanuckQx4
its pitch black but Ill find a pic hopefully in my camera of the engine or on google and highlight it, gimme 2 min
Thanks
CanuckQx4
Looks like it goes towards the air box area
asnorton44
Car: 2001 Infiniti QX4
Here is a pic from my engine:
Pwnin O'Brien
Yeah, when I installed my K&N intake I had a barb for that hose but the '03s don't have that hose. It should still be connected to the intake. The question is, what is on the other end of that hose?
CanuckQx4
So you think I should drill and tap in a barb on my intake and add that line to it? Before the MAF Im assuming
alexf20c
Car: '00 SE 4x4
your QX4 is running great otherwise, so why mess with it? fold a kink into that vacuum line and tie a rubber band around it. (or find some "fancier" way to plug it.) put the plastic cover back on and be done with it. obviously it's not that important. if the K&N kit is designed to plug that line, how important can it really be?
goody90q45
Car: 1992 Infiniti Q45 (sold)
I think you may have found the source of your P1110 code. The vacuum hose diagram is in the emissions section of the FSM.
p1110-the-code-that-wont-go-away-t517831.html
(Too many threads in too many forums for the same problem)
Pwnin O'Brien
alexf20c wrote:your QX4 is running great otherwise, so why mess with it? fold a kink into that vacuum line and tie a rubber band around it. (or find some "fancier" way to plug it.) put the plastic cover back on and be done with it. obviously it's not that important. if the K&N kit is designed to plug that line, how important can it really be?
Sorry, poor choice of words on my part. I meant to say barb, not bung.
CanuckQx4
goody90q45 wrote:I think you may have found the source of your P1110 code. The vacuum hose diagram is in the emissions section of the FSM.
How could this possibly cause P1110?
Canada sucks so much none of the auto parts stores carry 3/16" vacuum tubing so I had to order it. I plan on redoing all of the vacuum lines after taking a hard look at my motor, alot of the lines were in very poor condition
I dont get how this could cause P1110 though
goody90q45
With a plugged hose I can safely say that you're not getting vacuum to some component that in some way affects the intake sensor. I'm not sure either other than to say that the vacuum system and the P1110 intake sensor are on the same diagram of the emissions system so they are in some way tied together.
Page EC-26 of the FSM has an excellent diagram of the vacuum hose routing. You should be able to figure out where the hose goes by studying the diagram. There's a lot of good reading in this section that may explain what's happening.
Get the blanked off hose plugged in to the correct spot and I suspect your code will go away.
http://www.nicoclub.com/FSM/QX4/2001%20 ... System.pdf
CanuckQx4
Ya I seen that diagram but where they all bundle up in the picture I find it impossible to follow the one I painted in green in my above post. ON EC-26
They do all appear to go to the intake side, but its hard to tell what any of them plg into, especially since I no longer have the oem parts after installing my cold air intake
CanuckQx4
Changed all my vacuum lines today, just a pic to show how bad my oem ones were, they "looked" fine but after rubbing them with my fingers, they practically fell apart.
LOOK HOW BAD THEY WERE HOLY JUNK!!
alexf20c
Car: '00 SE 4x4
you could've used 5/32in / 4mm ID vacuum hose. most auto parts stores will carry that size, even in Canada! ;)
