KwayKer wrote:actually, its the opposite. It only makes the noise when its cold...like in the mornings
Yup its your belts alright.. just press down on each belt and tighten the ones that are loose.
The other problem may be that the pulley isn't on completely all the way, so its wobbling and that will cause the belts to screech also.
By the way, how's the car with the ASP pulley? Do you notice changes? And how's the idle?
