benemorius »
https://forums.nicoclub.com/benemorius-u17066.html
Fri Feb 18, 2005 8:28 am
Different things can cause different belts to squeal at different times. The power steering belt may only squeal while turning, the alternator belt may only squeal while it's under a heavy load, and the fan belt may only squeal while cold. The bottom line is - belts squeal if they're too loose, so check that all are properly tightened.
It could be something inside your engine also. Usually when someone says "screech" I think bearing (metal on metal), and when someone says "squeal" I think belt (rubber on metal), but it doesn't always happen that way. Hope that it's a belt. You don't want it to be a bearing...
