onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Thu Jun 28, 2007 8:23 am
Ok, First of all, wrong forum . It happens, just remember next time, post in the rite forum.
Anyway, did you just bolt up the quest alternator or did you do the necessary modifications to make it line up right? From the last time I checked & test-fitted, the pulley is off slightly compared to where the stock one lines up - this may be causing your squealling.
Other than that, it has to be either your belt is too loose or too tight. If it's been on too tight (or slightly off like the previous paragraph), it could have put too much stress on the pulley bearing.
