ejXa q45 wrote: the fan cluch would not go and still spin right, so when i was looking at this problem,i found that it might be a water pump.i think the coolant is also is not making its way in to the pump. the squealing, might be the belt on the pump not spinning right .i look at a pump and wont to know if this one, is the one to get.it leaking coolant from the left side of the radiator and can see the chemicals oxidized this is also why i think this is the problem.
The fan could either spin, or lock completely if the clutch is bad. The clutch should have less tension while cold, and more while hot - but never completely lock.
The part you show is the water pump... check to see if there's coolant coming from the weep hole on the bottom side. A dental mirror is helpful for this. When you say it's leaking from the left side of the radiator, do you mean the radiator is leaking - or you think coolant that's leaking from the pump is slinging over onto the radiator?
Either way, if you have a lot of coolant under there, it will tend to cause belts to slip as it drips on the belts.
Heath
