Thanks for pointing that out, I just made a typokingbingy wrote:Yeah looks good. But to be clear. You started off with 100 and worked your way to 600. (As the higher the number the finer the grit. Lower the number the more coarse it is).
As you guys need to know that you start ruff and then go higher with grit. Even close to 1000 grit would be great. Then you can use compound and polish.
But looks good.
Supposed to be wetsanded with 600 then 1000W O T wrote:Ya I did it last night, came out lookin great.
Just wetsanded with 600 then 100
Some of the lens refinish kits have 320, 600, 1000, 1500, 2000. That is just the sandpaper. Then you apply the polish paste. Most if not all of the sanding should be done wet, especially on the finer stuff.W O T wrote:That makes 2 of us, and it literally was no more than 40 min of work!! I thought I would be sanding with 600 and 1000 FOREVER to get the scratches out, but i was happy after only a couple mins
nope. i'm stophatin. it says i have a pathfinder cause im not trying to advertise my s*** to thieves !!W O T wrote:You have the same name over there?
