big cheap wally world gun, but it diddnt work the rpm gage doesn't go up either so im guessing i messed up my solder or bad solder being from wally..... or is there the possibility i put the harness back on wrong i noticed that the harness has a 3x3 plug and idk if that one can go in either way without a problem or if it will cause a problem. also still no illumination of the cluster. and i do have the dimmer switch plugged back in... im getting confuzed im going to look the cluster over for any more possible problems and possibly go over my solder again and try to get the copper a lil hotter
Wc240 wrote:get a defroster repair kit. has a kind of liquid electrical tape to protect your soldering.not to good, but alot better than the worst ive seen, especially for first time and im guessing a big, cheap gun. good job
