Scratch Shield really work?
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
Rfong
Are there any actual examples showing Scratch Shield really works?
What types of scratches does it heal - swirl marks, fine lines, rock chips?
What are the limitations?
Does the mark actually disappear or can you still see a shadow of damage?
Can you still detail the car with a random orbital buffer and cutting pads using swirl removing solutions?
infinitigurl
Car: All Infiniti's- I sell them
the scratch shield paint is an awesome feature. It only completely fixes the scratch if it is only in the clear coat, if it goes through to the paint, you will still see the scratch, but you will not feel it. Ideally, if you see a scratch, let the car sit in the sun for a couple of hours every day until the scratch is gone. It could take up to 2 weeks or so. As for detailing, I'm not sure... I can get back to you on that. I dont think our detail department uses a buffer on this paint.
EXceptional
Car: 2008 Aspen Pearl EX35 Freakin Loaded!
What would be neat, is if someone could some time-lapse photography on a Scratch in the Heat of the Day.
Omega-3
I heard its like regenerative armor. So take your key and scratch away and wait a few days to see what happens....
EXceptional
I'm not sure about the "Key" part.
Don't take his advice, OK ?
SprayTech
Car: 2008 Infiniti EX35 2004 Infiniti G35X
I am an Automotive Paint Technician of 30 years and this is new technology that I am interested in seeing , as I work at a GMC, Cadillac, Buick , Pontiac dealership , and am constantly buffing minor scratches out for customers .
It is only supposed to re-flow out minor scratches that are not through the clear coat finish .
I remember when GM came out with their chipless paint on their S-10 pick-ups , their TV add showed thousands of small ball bearings dropping on the hood with out a scratch , well they are smooth , unlike a jagged rock spit out by a tire at highway speeds , I sure re-painted a ton of S-10 front ends under warranty because it :O
They quit that advertising quick when it cost them millions of dollars in warranty repaints nation wide .
RCHarris
Car: '08 EX35 AWD Journey - loaded
I am sorry to report that scratch shield does not work as advertised - at least for me so far. I scratched the right front fender area - kind of a very light road rash scratch. It did not pentrate through the clear coat. I took pics of the scratch and have been taking them every three days. A week later and I can discern no improvement in the affected area. It has been cold here so I'm waiting until the exposed area has a chance to warm up more. I'll post all pics when I have waited a total of two weeks.Randy
EXceptional
RC... you guys in California should be capable of getting some Heat into that Paint.
Could you give your Car some good heat before calling it a failure ?
Up here in Alberta Canada, we have our Hot Days too, but they are not for long durations like you might have.
It'll be in the 90's and 100's for maybe a Month... and then we are done ! Summer is over.
morning_glory
Car: Infiniti EX35
So we're going to make our scratches being repaired between July 10th and July 30th since that approximatly our summer duration here in Quebec.Just kiddin' but last week when I was looking to some EX35's in my dealer backyard I remarked a fine scratch on a black EX35. I mean fine enough to make it auto-repaired based on what my dealer said. He said the process could take up to 2 weeks of warm weather,
We had an "under normal weather" May here so maybe it's not warm enough.
Anyway I did not buy my EX35 for that doubtful feature...
RCHarris
I'm giving it the benefit of a doubt and waiting another full week. We're supposed to have high 70s temperatures all this week. Let's see what happens. So far I am underwhelmed. I could very easily wet sand these scuff marks and buff them out by hand but I'm really curious to see if this miracle paint is going to work its magic.Randy
EX-lover
Car: Infiniti EX 35
good luck and please keep us posted!!
RCHarris
Apparently the scratch shield is beginning to work here are two pics. The first is the scuff on the first day. The second is the scuff 6 days later. Clearly the scuff is beginning to disappear. The scratches were made by a swinging wood door and did not penetrate through the clear coat. I expect over time even the dense scratches will go away. I'll keep posting and let you know:
dividedhighw
Car: 2008 EX35 AWD (Technology Pkg)
VERY Coool!!!!
I'm very sorry for your little "boo-boo" , but thanks for sharing, and yes, please do keep us posted.
majorloser
Car: Infiniti EX35 AWD Journey
Heck, if hot weather makes the paint softer...
I might come out one day to see a pool of paint sitting on the ground below my car.
EXceptional
Check out this LINK
myg37x
Car: 2009 Infiniti G37X
It absolutely does. I recently purchased an Infiniti G37X. When I say I am VERY anal about the exterior of my cars, it is an understatement. Heat is key to the magic of the self-healing paint and a significant factor in how quickly the scratches on the clear coat disappears. After scratching my car with my finger nail, I did a lot of research. With it being winter now, I would probably have to let my car sit outside for a couple of weeks to see any result. Instead, I poured very warm water (not boiling) over the scratch a couple of times. When I went back to check on it an hour later, VOILA! The scratch was gone! No joke! I would even suggest gently placing a microfiber that was soaked in very warm water on it. I think the heat and moisture combination helps.
Unfortunately, I have a bunch of scratches on my car after having my detailer clean it after a whopping snow storm. There was a lot of dirt on it. Even the best of the best can't keep your car scratch-free. Now I have to do some damage control. Once I get it back to it being scratch/swirl free, I will clean my own car. I'm absolutely bummed that they stopped putting the Scratch Shield on the Infiniti G.
Hope this was helpful. Good luck!
ramprun
Car: Infiniti EX35
this link shows how well scratch shield paint works. it is in chinese but you don't need to listen to see those scratches disappear.http://www.youtube.com/watch?v=n5gaA47cmLA
dentmandan
Car: nissan
Looking at the pictures of the scuff that night be transfer try using solvent
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
