jrod106 »
https://forums.nicoclub.com/jrod106-u166739.html
Sat Oct 23, 2010 4:47 am
Thanks for the suggestion. I didn't need anything however - all the color code information was on the bag for the wiring harness that I bought. I used that info (which matched up perfectly to the wiring harness for the radio - JVC KW-XR810) - soldered all my connections, put shrink tubing over each wires connection, and was ready to do the install. 15 minutes to install - probably even 10 (although i still have to run the wire for the bluetooth mic). Looks and sounds better than the stock unit.
Just in case anyone would like the info - below is everything I bought for the install .
Scosche Double DIN kit - NN1644B - $19.95 direct from Scosche, $11.75 from Amazon
Scosche Wiring Harness - NN04B - $12.95 from Scosche and/or Amazon
Scosche Antenna Adapter - NAA2B - $19.95 from Scosche, $9.94 from Amazon
eBay prices would probably be even cheaper.
