Davezilla »
https://forums.nicoclub.com/davezilla-u195464.html
Sun Nov 11, 2012 10:18 pm
Quick schooling on the electric choke...
If it's functioning correctly it works great, but if it needs an adjustment it can give you some fits... Best advise I can give you is to set it up either with the engine fully warmed up or completely cooled down. Since the mornings are just now starting to cool enough to make your carburated engine difficult to start up, this is a good time to set it up with the engine fully warmed up.
First thing we need to do is loosen the 3 screws that hold the choke thermostat in place loose enough that you can easily turn the thermostat, with the warm engine we want the thermostat to be fully open so let's move it to full open if it's not already, but since you said your engine is getting hard to start I'll assume it's already fully open so let's back off from the open position til you see it start to move to the closed position, then set it to where it's open again and lock it down. If the thermostat is working correctly, when it cools all the way down it should snap shut when you step on the gas or open the throttle from the carb and it's a done deal.
This of course is all that's needed if the thermostat is working properly and there's no binding in the linkage etc...
Now let's say the engine is fully cooled down and hasn't been started yet today, you can adjust the choke to the fully closed position and lock it down, then start it up and it should open to the full open position as the engine warms up and usually in about 5 to 10 minutes. When adjusting it cold you'll want it to snap shut when you step on the gas or open the throttle at the carb and you'll need to hold the throttle open while adjusting it so the lock out mechanisms won't prevent adjusting. You can reset the choke to open the butterfly valve by holding the throttle open and moving the valve to check for range of motion if needed, but the basic adjustment is to get it to fully shut, then lock it down, then open up the throttle while holding the butterfly valve on the choke open and release the throttle, now open the throttle again to make sure it snaps shut and you're done but you'll need to make sure it opens all the way once warmed up.
There's a vacuum operated choke pull off in the system that does exactly that... it pulls the choke open when you step on the gas to take off while the engine is still warming up, if the choke pull off isn't working you'll know because your engine may bog from the choke staying closed when you take off from a stoplight etc... You can test these with a vacuum pump to make sure they pull back under vacuum, but that's all there is to testing them, either they work or they need replaced.
The other part of the system is the fast idle cam which moves with the choke valve which allows the engine to idle at a higher speed during warm up to prevent stalling, this needs to be adjusted with the engine cold and at idle, so be sure you have access to this adjustment screw before starting your engine if it needs to be adjusted. The fast idle is usually set around 1300 rpm but check the manual to be sure.
things that can cause the electric choke to malfunction other than being out of adjustment is usually carbon build up in the linkages which can prevent the linkages to move freely, bent or improperly installed linkage rods, and if the thermostat is just worn out and will no longer move from full closed to full open and vise versa, but this one is a rare occasion since usually another adjustmsnt will fix the problem.
My final note on choke adjustment is that it's always easier to adjust them with a fully warmed up engine since you only need to open it enough to reach the full open position with no extra tension on the choke valve, then it won't matter how cold it is when the engine cools since there will always be enough tension to hold it shut as it warms up, and it'll always reach full open after the engine reaches operating temperature so no further adjustment will be needed. Yes, you can adjust it with a cold engine, but you may need to readjust it after it warms up if it's not opening all the way or not closing all the way on the warmer mornings.
