Schedule reminder
M35Lunatic
Car: 2007 M35
Hi,
Does anyone have a problem with the maintenance schedule reminder? My problem is after I reset the reminder, it wont show the mileage on the screen to let me you know how close are you until the next service.
Please, let me know how to fix it and thanks in advance.
Ilya
M35Lunatic wrote:Hi,
Did you reset it or reset and disable it? I think you can also disable it.
M35Lunatic
Car: 2007 M35
You can reset it and turn on or off the reminder but I kind of like the reminder, it helps letting you know when the next service is.
splix
Car: 08 M45X
It wont show a mileage number other than what you set it for. It will show a bar graph move along until it hits the arrow, which is sitting at the mileage you set. ie: every 4000 miles reminder 1.
Ilya
M35Lunatic wrote:You can reset it and turn on or off the reminder but I kind of like the reminder, it helps letting you know when the next service is.
I know how it works, I use it. I am asking if you accidentally disabled it. As said above, it won't give you mileage. It will only pop up on the screen when you start the car once you have hit the marker.
M35Lunatic
Car: 2007 M35
Thank you for all the responses and inputs. I've used this before and it worked fine, but I noticed this problem months ago. I tried to reset and still dont see the mileage bar showed after couple week driving.
Ilya
M35Lunatic wrote:Thank you for all the responses and inputs. I've used this before and it worked fine, but I noticed this problem months ago. I tried to reset and still dont see the mileage bar showed after couple week driving.
So you're 100% sure it's not disabled?
M35Lunatic
Car: 2007 M35
Yes, sir. I'm SURE.
Ilya
Okay, I was thinking maybe you're a lunatic. :gapteeth:
That's really odd...
