SCE Gaskets for KA24DET
95_240sx
Car: My baby (car)
Anyone ever used one of these aftermarket head gaskets on a KA or KA-T? I havent heard much about them and I was hoping I could find someone who has experience with them.
Was it worth the money? How much did you pay? Was is quality and is it a good investment?
ThanksRick
Exar-Kun
Car: 2005 350Z
uh, I have never used them, but if it counts, I plan to.Almost every good turbo buildup I have seen makes use of a copper/steel/metal headgasket to aid its durability....regardless of the thickness of the gasket(raising or lowering compression ratio)...-chet
95_240sx
Car: My baby (car)
what about 438 rwhp on a stock head gasket? Thats what chris may did, and no problems. Do you know what the going rate for the SCE Gaskets are?
Rick
240 or die
Where can i get a metal hgasket for my ka. Looking to lower compression for turbo.
Exar-Kun
Car: 2005 350Z
http://www.scegaskets.com/index.htm
I think they're like 200? Im not sure...
chris may lives close to me, and I take my car to the place he got his built up at, which is maybe 20 minutes from my house....and jeff over at BaPo says it'd be a good idea to hve the metal headgasket, not because its required, but it can save me some headaches if I experience a problem..
-chet
95_240sx
Car: My baby (car)
Im going to give it a try with just a o-ringing mine, if i blow it, which I would rather blow a head gasket if (which I wont) I get detonation, rather than blow a piston into next week, I will change the the SCE Gasket and hope I dont lower my compression too much.
Rick
240 or die
Chris has the twin turbo setup huh?
240 or die
And as far as i know lowering the compression will help for turboing, right. So would the metal gaskets give you a little reassurance and added performance or not?
cnichols
Car: 96 Nissan 240SX
99 Infiniti Q45
93 Ford Fastiva
240 or die wrote:Where can i get a metal hgasket for my ka. Looking to lower compression for turbo.
"A variety of methods exist to change a compression ratio. Almost ALL are UNacceptable....It is possible to err so badly in removing the squish that a resulting 7-to-1 compression ratio may ping worse than a 9-to-1 with proper squish."
If that made no sense to you, then go buy "Maximum Boost" by Corky Bell and read every page before you put a turbo on your car if you want it to last.
C-Kwik
95_240sx wrote:Im going to give it a try with just a o-ringing mine, if i blow it, which I would rather blow a head gasket if (which I wont) I get detonation, rather than blow a piston into next week, I will change the the SCE Gasket and hope I dont lower my compression too much.
Rick
Unfortunately, with detonation, you can't predict what will happen. It's not like a simple mechanical issue of the weakest link breaking first. In essence it can break several things at once. Usually it's limited to one thing, but depending on where in the combustion chamber and at one point, etc. it can damage the piston before it damages the head gasket. There's is just too much to consider...
Exar-Kun
Car: 2005 350Z
Im going to probably use a stock thickness head gasket, and go from there....
that way, I dont mess with the head design and stuff....-chet
C-Kwik
Just wanted to note a great positive of a metal headgasket. The OEM gasket is a pill to remove. It's stuck to the block and head real good. If you blow something up after you replace the head gasket, at least it will be a lot easier to do the work. Especially considering that it is quite easy to damage the mating surfaces trying to remove the OEM gasket and you would have to send it to get decked.
1991240xs
240 or die wrote:Chris has the twin turbo setup huh?
no, single turbo...no point in a twin turbo setup on a 4 cylinder-
Exar-Kun
Car: 2005 350Z
no point in twin sequentials on most cars anyway...thats why most supra/RX7's goto single turbo upgrades...Chris May has a heckuva setup on his 240, and Im working with the shop that built it, they gotta help be find the injectors i want and stuff..
anyways....im tired. Imma sleep now.-chet
95_240sx
Car: My baby (car)
Exar-Kun wrote:no point in twin sequentials on most cars anyway...thats why most supra/RX7's goto single turbo upgrades...Chris May has a heckuva setup on his 240, and Im working with the shop that built it, they gotta help be find the injectors i want and stuff..-chet
Im 95% sure he has MSD 72lb injectors, JWT computer, and JWT fuel Rail, as well as a Walbro 255/lph fuel pump, Im not 100% sure, you can always call him and ask him, he is always willing to help out another 240 lover in need of some direction and help.
Rick
doctorj240
Car: Black s14 w/ redtop
or you can visit his page http://www.executivecleancar.c...s.htm
95_240sx
Car: My baby (car)
That Works too
Rick
cnichols
99 Infiniti Q45
93 Ford Fastiva
What's the stock head gasket thickness by the way so I know what size to order?
And, I've only found one place that carries these...any suggestions?
