SCCA help?
goomba240
Runnin SCCA this year with the new "Track car". its a 91 FB with a 93 motor and 91 cams swapped in(motor has a little over 60k) also has the following-Cusco Sway bars-Kyb Agx struts/eibach pro kit-JIC magic F&R STB'S-JIC tension rods-B&M short shifter-spec stage 3 clutch/"extreme" pressure plate-brembo slotted rotors/Endless pads/braided lines-89 seats(a little more race style, shouldnt get in troube for these)-pacesetter header(heat wrapped)-apexi duals-test pipe(may get in trouble for this one, anyone running one in my class?)-GTO direct steering bushing(not installed yet got it off Jspec for 40 bucks and have NOO idea how to put it on)-A few other things I will add later, forgeting things sucks-VLSD(got it outta another S13 so it should be okay)
Well im goin out for SCCA solo 2 Street Touring X, Just wondering if any of these things will get me bumped up to Street modified 2(I really dont want to). Any opinions welcome on what to do/get ... May throw on a UR pulley set since removing accs. is prohibited.. Also have a CAI layin around I could put on, would these be allowed? Only thing I have ran before is Stock class so this whole modded thing is new to me.. And are any of you guys out there running the Street touring X class? If so what mods do you have?
goomba240
Oh and one more thing it has NGK plugs and wires, Would the tech's give me crap for these?? I really want to run Street Touring X and I will take off anything that will get me bumped up to Street Modified 2. Thanks
