GT3Nissan »
https://forums.nicoclub.com/gt3nissan-u25036.html
Sat Dec 01, 2007 3:34 pm
I finished 4th in GT3 and I run a 200SX, not S14 (of course I have an S13 IT car too, so I keep up with this site). GT3 has been around for many years, and before that is was D production, I believe. Nissans run the KA24E with ITB or stock based fuel injection and 34mm(?) chokes. You can also run the KA24DE like the pole sitter, with any injection/carb, but behind a 33mm Single Inlet restrictor. I run a hybrid L20 without intake restriction an much less weight to try to keep up.
There is no way to run a GT3 motor of any kind on the street. 13.5:1 would be a conservative motor, with SIR restricted motors having much more compression. The engines do idle, it's just lopey and have to be at about 12-1500 rpm for my motor. The KA24E guys run up to about 8000rpm, but have some reliability issues with the valve train. KA24DE guys have more reliability, run to about the same rpm, with the same weight, and seem to be the wave of the future.
The Nissan Motorsports catalog is pretty good for parts, but they don't have everything you need. Rebello is probably the best source for parts. Mine is carbureated but being converted to ITB throttle bodies for next year. 2008 may be the last year for GT3 since we don't have enough competitors running Nationals. It's really too bad since the slower GTL class is too slow for the cost and the faster GT2 class guys spend a fortune on 18x12 wheels and tires.
Steve Spiers
