Buzzman »
https://forums.nicoclub.com/buzzman-u55955.html
Mon Mar 09, 2009 8:13 am
Ok,So I'm driving home today, in AWD (snowy day today), and I'm less than half a mile from home when I hear a small clunk, and then the loudest most awful rattle/clunking noise I have ever heard.I pulled over, and a thousand things come to mind.The engine blew (power valves?), or maybe my transmission let go. After I stopped, the engine is still idling smoothly, and no noise.I get out to look under the truck cause I thought maybe a drive shaft had let go and was dragging on the road. Nothing hanging down.Then I thought maybe one of the front brake pads had delaminated and broke loose. (had it happen with another vehicle).Checked the brakes as best I could. No visible damage.Not sure what to do, I slowly did a u-turn and decided to limp it in to a local repair shop, less than a mile away.Barely moving with the four ways on, it's making a huge amount of noise. Everyone on the sidewalk is giving me funny looks and pointing at me.Yea yea I know. I can hear it too dumbass.Decided halfway there that I was risking major damage, so I pulled over again and was going to call a tow truck.Had one more good look underneath (kneeling in the slush), and lo and behold, there's a piece of the heat shield, jammed between the frame and the driveshaft coming out of the transfer case.Pulled out the piece of shielding, and voila, problem solved.I never knew a piece of metal could make that much noise. It was rubbing against the u-joint of the drive shaft. You can see the mark on top of the Nissan stamp on the shield where it was rubbing.All I can say is whew. I was shi**ing bricks for a while.Thanks for reading.
