ricebike »
https://forums.nicoclub.com/ricebike-u5064.html
Sun Apr 16, 2006 7:12 pm
OBD I had consult port it's located by the d/s fuse/ kick panel...
so if you're too lazy to remove the ecu from the pass side kick panel, some dealer techs can just plug into this port w/ their pre OBDII scanners & see what the ecu see's...
i think someone here had made a plug to directly go into that port & you can see what the ecu is reading... i didn't follow thru w/ that endevor since it wasn't hard for me to pull the ecu the regular way... it would b nice, though...
