Rockhound wrote: the ScanGauge is getting a reading via the OBD system from that same float - so then it's just a matter of how the analog dash gauge displays that value, I suppose.
How much is the variance between the two readings, for speed and gas?
I don't understand something , if you ask how it compared to trip computer you have built-in (in the TIIDA you such a gadget ) , I guess Rockhound is right it reads from the OBD , more then that I think that basically all the Versa's has Trip computer - and it's only matter of if it's "enabled" or not , if you want to calculate your gas consumption - it is accurate - like most of the tanks - is has difficulties reading how much gas left in it. BUT the ECU knows exactly how much gas ihas been pumped and goes to the injectors ,every second (in the TIIDA the trip computer tells you the immediate consumption when you don't step on the exelarator it indicate 0 L/100km ) and if it can estimated how gas left in tank it can display by simple calculation how far you can drive till the next gas station.
