SCALE Coilovers for AWD M37
wideopn11
Car: 2012 Infiniti M37x Moonlight White
Takeda CAI
Stillen exhaust w/ MeganRacing Y-pipe
SCALE coilovers 16K/10K F/R
Akebono BBK
Cusco strutbar
25mm spacers F/R
Uprev tune by seymore4
I haven't seen much on these coilovers; I think only one person on here has them that I know of and he's not replied to anything.
http://scalesuspension.com/shop/en/infi ... inal_color
I like that these have height marks right on the sleeves for easy adjustment. I may get these over BC just because of that. If anyone has info or knowledge on this brand please share.
DubXSY51
Car: 2013 Infiniti M37X S (Y51), former owner of 2006 M35 (Y50)with tech package, 2002 Maxima, 2000 Maxima
Like them also, curious to know how they perform...Nice work finding them!
Ilya
I plan to get these instead of BC's now that I know they work on M56x's. The marks are a HUGE help.
PostalsQ
Look like a nice set up
mikedamageinc
Car: 2012 Infiniti M37x Touring
1999 Chevy Camaro SS
1997 Toyota Land Cruiser
2008 GMC Yukon Denali
The marks are good for a starting point but many cars aren't perfectly even anyways. Plus if you are really going for handling, corner balancing is key and will make the height vary slightly.
wideopn11
Takeda CAI
Akebono BBK
Cusco strutbar
25mm spacers F/R
I don't know man; from my experience doing coilovers on my old RX7, having those marks would have saved me a lot of time dialing in the ride height. Lift the car, remove the wheels, adjust, put the wheels back on, lower the car, measure, repeat. It took a while; and with my OCD to get it perfect within a millimeter at all four corners, yeah it took a while.
wideopn11
Takeda CAI
Akebono BBK
Cusco strutbar
25mm spacers F/R
Ilya, when are you doing your suspension? I noticed SCALE also has a Swift Spring upgrade; I'm wondering if it's worth the extra money and what spring rates to go with. BC lists 12/08 F/R for their Swift Spring upgrade.
wideopn11
Takeda CAI
Akebono BBK
Cusco strutbar
25mm spacers F/R
I got a quick reply back from SCALE about their spring rates;
Standard: 14kg Front & 08kg Rear /// Swift Springs and Low Version: 16kg Front & 10kg Rear.
PostalsQ
So if you had to lean to one side or the other. Knowing these cars weren't really built for cornering like the 370/G60 per say. I'd say more built towards luxury ride with some occasional spirited driving. Which coilover would you go with? BC or Scale?
Ilya
wideopn11 wrote:Ilya, when are you doing your suspension? I noticed SCALE also has a Swift Spring upgrade; I'm wondering if it's worth the extra money and what spring rates to go with. BC lists 12/08 F/R for their Swift Spring upgrade.
Whenever my stock stuff starts to go bad. I'm at about 96kmi right now...so I'm guessing within the next 25-35kmi.
CRV_33
Car: 2011 Infiniti M56x
I have Scale coilovers and installed them about three weeks ago. Took about 9-10 weeks to get the set of coilovers and an additional two weeks to get everything straightened out since they installed the wrong top hats and bottom forks on the rear coilovers. I know two other people that ordered from Scale and they messed up their orders as well, but they were able to resolve their issues. Just be forewarned.
It's been since three weeks since I installed them and overall I'm happy with it. I've been playing with the damper settings and I can feel the difference. We initially set the damper to 6 (out of 12) and then a couple of days later I set it to 12 to see what it felt like at the hardest level. I ended up dialing back to 4, and honestly it feels about where OEM is.
Ilya
CRV_33 wrote:I have Scale coilovers and installed them about three weeks ago. Took about 9-10 weeks to get the set of coilovers and an additional two weeks to get everything straightened out since they installed the wrong top hats and bottom forks on the rear coilovers. I know two other people that ordered from Scale and they messed up their orders as well, but they were able to resolve their issues. Just be forewarned.
Good review on the CS, glad they at least resolve their issues.
ARISTOCRATQ70L
Car: 2015 Infiniti Q70L
So you think Scale is better then BC's because I have heard a lot of mixed reviews about BC's
CRV_33
wideopn11 wrote:
Fri May 05, 2017 10:35 am
Hey wideopen how are you liking your ride?
I currently have the standard 14kg and 8kg spring rate, it is soft but at times can be a bit bouncy sometimes. To anyone looking to purchase Scale in the future, I would recommend something slightly more stiff to reduce the bounciness.
stevstep77
Car: Before 2009 Infiniti M45x aka BIGHEEM
Now 2015 Infiniti Q70L aka BIGHEEM2.0
Anyone have this setup with a different spring rate? Being that CRV_33 said the 14/8kg spring rate was bouncy, has anyone tried a different rate? Was thinking about going with a 16/10kg maybe that would be stiff enough to stop the bonce feeling.
wideopn11
Takeda CAI
Akebono BBK
Cusco strutbar
25mm spacers F/R
Check the front page of NICO; I did a full review of SCALE.
http://www.nicoclub.com/archives/scale- ... -m37x.html
I wouldn't say my spring rates are bouncy; they are stiff. The whole car moves over dips and bumps. There is very little travel and it settles right back to flat almost instantly.
SwissCheeseHead
Car: 11 M37x, 94 BMW 530i
nice write up! Good to see another option for us AWD guys.
Squathomas
Car: 2013 Infiniti M37 S
Thanks to you, I just bought and installed my scale coils also. I did not get the "Low" version, just the regular version to bring it to a lowered, but still kinda stock/flush look.. insane pleased with it. With the wheel spacers, it's ridiculous. Totally more aggressive look to the car.
wideopn11
Takeda CAI
Akebono BBK
Cusco strutbar
25mm spacers F/R
Squathomas wrote:
Fri Nov 10, 2017 3:27 pm
Nice! Post some pics.
