SC VH45DE in a R33 Skyline
94sky
Hey all, i was on here quite a while ago with my Vh45DE powered R33 that some of u may remember, well now i have taken the next step and added a vortech T-Trim supercharger, programable ECU, Intercooler and a few other goodies. Its not yet running, but im hoping to have it completed in the next 2 weeks.
Let me know what u guys think.
Cheers
John
Looneybomber
Car: 02 explorer sprt (grn)
10 G37S (white)
Sounds a bit crazy, but I definatly like that you're thinking "outside the box". So what made you swap out the RB?
Oh yeah, post more pics!!!11!
94sky
Ummm, skylines are super common in australia so i wanted something that would stand out basically. Can anyone give an estimate on how much power the car will make running ~7psi intercooled and fully tuned?
Full details and pics on the car here http://www.teamkrazy.com/australia/rides/johnv8/
sean8564
Car: 1993 Nissan GT-R V-Spec
1991 Nissan 300ZX TT Black
1993 Nissan Silvia
1990 Nissan 240SX Coupe RB25DET
that look crazy I like it why not do a Vk45Dett
gabossie
Car: Your mom
very nice setup. I'll be eager to see the finished result and some numbers!
PantherRacer
Car: 1992 Nissan Skyline R32 RB20DET Sedan
MMMMMMMMMMMMMMM V powered skyline, agagagaghagh *drools*
DAEDALUS
Car: 1990 Infiniti Q45
I'll guess 330-350 at the wheels at 7 psi.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
I love it. It's perfect.I'd rather have a VH than an RB any day.
94sky
sean8564 wrote:that look crazy I like it why not do a Vk45Dett
No room newhere... its tight with just the VH45 in there.
gniknave
Car: 2000 Audi A6 2.8 Quattro
2008 Honda Civic EX (Sedan)
I hope that VH has updated chain guides
94sky
Ev_eezy wrote:I hope that VH has updated chain guides
yeah we did that before we originally put the engine in.
DAEDALUS wrote:I'll guess 330-350 at the wheels at 7 psi.
Rob - Remember the BAD Q did WAY more than that at 6 psi. The VH responds VERY well to FI.
I'll venture 370, without emissions crap and on good gas.
94sky
sounds promising, How much boost would u say is safe to run? i have headers/exhaust, intercooler, fuel reg, modified fuel rale, intercooler and ecu of course.
Who did the boost map on the ECU?
I'd be wary of exceeding 8 lbs, but that's just because (to my knowledge) it's not been done before.
Megaseth
Car: 2002 Pathfinder SE
arent the VH45 internals good for around 500hp?
94sky
Microtech are building a custom programmable ECU for it. It does away with the airflow meter and uses a map sensor. Then the car will be tuned on the dyno.
DAEDALUS
I have to go with plain math. Volumetric efficiency is darn near 100% without FI. With 7 psi boost you can expect almost 50% more HP at most, say 450 at the crank (with better tuning than stock). What you back off for losses is open for interpretation. I used 25% (337.5HP) cause I'm trained to like my margins. If you can get losses down to 20% that would leave maybe 360HP at the wheels.
sensibleS13driver
94sky wrote:Let me know what u guys think.
I think you're crazy, but in the best possible way.
VH R33 put them together, you've got yourself one hell of a Nissan
PoorManQ45
What is the trunk lined with?
Also, project looks good thus far, but one question: Isn't the supercharger outletfacing the wrong way?
PantherRacer
Either it's not installed, or he's gonna run more piping from its current location for a) clearance reasonsb) again being differentor C) he'll giv u tha real reason lol
94sky
The out let is there, off the outlet will be a 90deg mandrel down through the guard to feed the drivers side of the intercooler out the other side of the cooler back up through the passenger inner guard and into the throttle body.
The boot is just painted body colour and all un needed wiring and sound deadening removed as with the back seats and so forth. The car is getting a full cage to comply with our drag racing rules over here. So far all that is left is to finish the fuel system, machine the pulleys, and wire up the computer when it arrives as its not plug and play. Oh and repaint the ugly looking parts of the engine bay.
94sky
On most of the dyno's over here the car made between 230-250rwhp so would it be safe to assume on the same dyno it would make at least 400rwhp with losses. All it had was a custom set of header pipes and 3" exhaust.
PoorManQ45
Ah, I forgot about the intercooler. now it makes sense
94sky
just picked up the cooler so i can start on the cooler piping now... its getting there, still waiting to hear about the computer though.
94sky
More progress on mine, all the pulleys and adapters have been made intercooler mounted and piping done, Just have to make an idler and tensioner, finish off fuel system, wait for my computer to arrive and wire it up.... its booked in on the dyno on friday afternoon.... see how it goes....
Nismo_Freak
Car: 89 Nissan 240SX
383whp / 365 lb. ft. @ 7 PSI
Thats if it's a true 7# ... and not a 7# pulley.
If it's a 7# pulley then you will see about 5.5# of total boost with that oversized intercooler.
sean8564
1993 Nissan Silvia
looks good
94sky
sounds good... the only reason we went with a cooler that big was for future plans to the car... i dont have enough money to throw things like that away and buy a bigger one when the time came and i needed one that size.
Nismo_Freak
94sky wrote:sounds good... the only reason we went with a cooler that big was for future plans to the car... i dont have enough money to throw things like that away and buy a bigger one when the time came and i needed one that size.
Cool.
Nexus9
Car: R33 GTST VSpec Skyline
my my John you do get around
I have seen this car in the flesh and it is awesome ... sounds soo good.
nothing beats that V8 rumble
