tollboothwilley wrote:I have a similar setup. I run 0 gauge wire to the Sub amp with a 1F capacitor.
What I think you might want to try is to upgrade the Battery Neg -> chassis ground. Also upgrade the Alternator ground -> Battery Neg.
Those are the only wiring upgrades that could be beneficial, aside from rewiring the amp with 0 gauge.
From what I see is that the battery ground has already been upgraded to 4 gauge which should be good for about 135 amps. But.......... if you are driving 900 watts rms. then the rule of thumb that is often used is to allow an additional 40% for actual amp loading. This gives about 1260 watts.
At 12 volts this would give you a draw of about 105 amps. #2 would give you about 181 amps. According to the FSMs you have a 110 amp alternator on a 2005. Previously when I looked into this the fuseable link for other models ran 140 amps which is typical for an alternator with a 30% fat in its rating. Keep in mind that one is not likely to be driving around at 5000 rpms all day, the max rating for the alternator. At a crusing rpm of about 2500 it isn't even 100 (keep in mind alternator speed).
Now consider that once the car is started you are basically running off of the alternator, not the battery. While the battery cables to the amp are in range this doesn't take care of the undersized alternator. Even with its fat you are potentially loading right on the upper limit during the high output transients. Increasing the battery cable size will not increase the capacity to the amp except when the car is not running, it will only mask the real issue on a very limitied time period with the car running. What needs to be done is to increase the alternator capacity keeping in mind that that it may be necessary to also upgrade its cabling as well since that is what is really supplying the car with its power. You can't get 200 gpm of water to your house with a 150 gpm pump regardless of the size of the pipes.
The separate battery will only help if your actual draw averages less than what the alternator can supply, it actually decreases to a certain extent your long term capacity.
One thing to check is to see if the amp is actually clipping during the transients. This isn't unusual and goes largely unnoticed especially for subs. The point here is that the amp is rated 900 watts rms. In the case of a sine wave this is most likely the rated power output. But if you are clipping then the actual output of the amp can increase substantially as you approach a square wave. Along with that comes an increase in the power it requires from the electrical system. This is something to look at as the fix then would be to turn down the inputs until clipping disappears. Still doesn't cure the 110 alternator.
Perry
Modified by pfarmer at 12:03 AM 9/2/2009
