Which transmission did you use? If the T5, how did you deal with the shifter being forward of the OEM shifter hole?sctrep wrote: ive gotta say, i just droped a 90 302efi into my 240sx. with the transmission still attached and it is amazing how well it fits. by the way how many ford efi's have you seen or heard about in a 240sx. im gonna post some pics hopefully soon. and a vid or two when shes done.
I'm sure it helps, but I've still seen them split with both girdles. Best bet for high horsepower is an aftermarket block.tomkun-s13 wrote:If you go with a 5.0 swap you can buy a valley girdle guard and a a lower main girdle and the 5.0 will not split and you can rev it to 7500rpm safely. check this site out http://www.horsepowersales.net/ hope it helps.
I was talking more along the lines of a 4 bolt main block such as the R302, Dart, or World one. I wouldn't worry with any of those.tomkun-s13 wrote:Well I've seen first hand the motors last a hell of a long time with these parts. Whats the big deal about the frpp cast iron 5.0 blocks. Its just a ford exploder block that has all the casting flash removed from the block because the the numbers on the blocks are the same. if you are going to pay for a frpp block just take your own block to the shop and have it polished and flash removed and run 500hp very safely and set your rpm limit to 7200 if you want to be safe.
Vroom...thanks man! Hopefully I'll be out drifting next MM.
Which T5 has the shifter forward of the OEM hole? The chevy/ford t5's shters are in different spots...KATwo40 wrote:Which transmission did you use? If the T5, how did you deal with the shifter being forward of the OEM shifter hole?
Unless you want to mount the transmission so far back that you can't unbolt it from the engine with out taking the engine out the distributor isn't really a problem...OutToWinPAHC wrote:The rear distributor on the Chevy does get in the way, its another reason I went with an LSX motor. But theres ways to make it work.
The tail section between gm(longer) and ford T5's can be swapped. You have to use the gm mainshaft though and world class and non world class stuff can't be interchanged. Check out some merkur forums, they do the swap. A freind of mine wrecked his 96 4.6L mustang and I've been getting ideas.KATwo40 wrote:
Thanks!
