Save my car from the firey depths it is facing...
KATwo40
Car: 1993 240sx KA-T
I'm not lookin' at the % readout, but actual voltage values. Even with the engine off, there is some voltage going through the meter and back to the ECU. I'm sayin' that the voltage should be different if the SAFC2 is dialed back.
WDRacing
Damn, my battery is totally dead, I was going to go mess with SAFC just to see if I could get some readings for you to try/eval. Sorry brah...
WD
Chezedik
Car: 1991 Nissan 240sx
I don't see how ground can be a better ground than your pen15.
KATwo40
Ignitor.
That is all.
Bosrudorfer
Car: S14
What about your injectors... Maybe stuck open or leaking....
KATwo40
The ignitor fixed it.
Injectors were replaced.
Chezedik
The ignitor sends the signal to the ECU from the CAS to inject, so I guess it makes sense. Doesn't explain the voltage though, does it?
KATwo40
It doesn't, but further testing does...
I checked both MAF voltages (before and after the SAFC2) while cranking and the differences were in agreement with the SAFC2 correction factor.
So, the SAFC2 receives my apologies for the names I called it.
kings_blend
Car: S13
Have you checked for any leaks at the intake manifold? Could be leaking air that was read by the MAF and throwing more fuel in to compensate but the air could be escaping from a leak. Just a suggestion...
TrunkMonkey
Car: 2000 Lincoln Navigator
kings_blend wrote:Have you checked for any leaks at the intake manifold? Could be leaking air that was read by the MAF and throwing more fuel in to compensate but the air could be escaping from a leak. Just a suggestion...
i used to fail my book reports when i tried to use cliff's notes instead of reading thru the entire story.
glad to see you got it fixed KATwo40.
-demetrius
