philipa_240sx »
https://forums.nicoclub.com/philipa-240sx-u68765.html
Sun Jul 06, 2008 6:59 am
Putting it in neutral may make a slight difference. Here is why:
When in drive, the motor is having to spin the torque converter (bascially a fluid coupling) against the now stopped wheels. This puts a slight load on the motor and the energy is lost as heat. When in neutral, the forward drive clutch disengages and the only load on the motor is the power needed to drive the CVT's hydraulic pump... which is very little.
It won't be huge, but it will make a difference and every bit helps. Idling in neutral should not harm the CVT.
Obviously you would be further ahead by turning the motor off. I do this all the time esp. at major intersections where stop light cycles are very long. I restart when the light turns amber for intersecting traffic, this way I am ready to leave as soon as my light turns green.
On the topic of hypermiling and the CVT...
One thing I DO NOT recommend is coasting in neutral with the engine off. Not only does this leave you without power brakes, the CVT hydraulic pump will not operate without the engine running and damage could occur from lack of lubrication.
