808datsun510 wrote:I also wanted to ask you guys, ball park estimate of how much you guys are spending for doing a basic swap besides the engine its self, and how you are guys doing it as far as fabricating your own parts
with an RB motor there is no "basic swap."
i went with mckinney mounts, downpipe, driveshaft, etc, because they seemed the best bang for the buck. I didn't want to track down a skyline crossmember just to use the syko kit and have to buy extra **** just to keep a stock turbo i would be getting rid of soon.
But like I said, there is no "basic swap" with an RB. With an SR, you can just drop it in, change wiring a bit, and you're set. With an RB, you should change the clutch, and whatever else you can afford to while the motor is out of the car. In the engine bay (in an s13 at least), there is very little room to maneuver. A simple clutch change can only be accomplished by lifting the car up overhead (hydraulic lift), and dropping the motor/crossmember and transmission so that you can separate the motor and transmission. You can't just drop/angle the transmission because the rear of the motor is extremely close to the firewall.
I'm not gonna go into detail about everything you need to acquire to actually swap the motor in, but keep in mind the simple maintenance parts that will just ensure reliability and long-life out of your RB motor. Also, with research, you will find parts you can use on the cheap (mostly 300zx, 1.8l old-school sentras, and some older cars with CA18s.)
I replaced simple **** like my clutch slave cylinder, IACV, ignitor chip (S1), all new spark plugs all around, fuel filter, new oil pan, etc..
I'd recommend 3-4000$ extra to play around with.
