Satellite Radio???
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
mfmcleanG35
Car: 2003 Infiniti G35 Coupe
I have a 2003 G35 coupe with non bose radio. It has a SAT button but i'm not sure what type of satellite radio it has. Anyone know how to help or program?
Thanks!!
smockers83
Car: 2006 G35 Coupe
If it has satellite radio hooked up, just listen to it to figure out which one you have. I'm not sure how the new programming is working now that Sirius and XM have merged. But if you want to program presets, you just find a station you like and hold a numbered button.
You could also go to your trunk and take out the mat. On the left side by the spare tire, there's a plastic piece and under that is where the satellite radio box is at. It should have which provider you have on a sticker somewhere.
pfarmer
Car: 2008 GXS with technology package
mfmcleanG35 wrote:I have a 2003 G35 coupe with non bose radio. It has a SAT button but i'm not sure what type of satellite radio it has. Anyone know how to help or program?
Thanks!!
I believe if you go to channel one it will tell you what you have. There should be a menu option for giving you the code for the radio which I believe may also identify the provider.
Perry
mfmcleanG35
When I click the SAT button, it says NO SAT- therefore I assumed there is no antenna or do I need to subscribe?
pfarmer
mfmcleanG35 wrote:When I click the SAT button, it says NO SAT- therefore I assumed there is no antenna or do I need to subscribe?
I assume you are outside. With XM radio (not sure which you would have if any) typically with the antennae and radio installed you have access to the default station number one. This will tell you how to subscribe, etc. Depending on the radio there is an option that would tell you the radio id number needed to subscribe.
http://www.infiniti-parts.com/hot.php?cat=satradio
This link is for 2005-2006 coupes and I think up to 08 sedans for retrofits, not sure about the earlier ones.
Perry
hawd_s14
Wow I think im going to end up subscribing. Need to check the trunk first tho :o
pfarmer
hawd_s14 wrote:Wow I think im going to end up subscribing. Need to check the trunk first tho :o
Again, depends on if you have it or not.
When I subscribed for my 2008 xs (XM radio) they told me everything about the car itself. It appears with a factory radio (all my others were aftermarket) that the radio id has a cross reference to the car including body type and more. Kind of set me back when the guy on the other end described my car to me.
Perry
Jwms
Car: 2003 G-35 Sedan, early edition
Saw this old post. Did you ever get sat in your '03?
Return to “G35 and G37 Interior, Exterior and Audio”
