rn79870 wrote:Welcome to NICO
I tried, and didn't get it either. I'd shoot off an email to one of the admins there and ask how to get it.
I found it but the pictures didn't copy?
How do I upload a PDF file?
GENUINE PARTS14 1516 1713 12 1110 9 8 7 61 2 4 351. DESCRIPTION: SATELLITE RADIO SYSTEM2. PART NUMBERS: XM tuner kit 999U9-NV003SIRIUS tuner kit 999U9-NV004XM antenna kit 999U9-VQ006Sirius antenna kit 999U9-VQ007Feeder cover 999V9-JQ0013. MODEL APPLICATION: G35 2-DOOR COUPE (2003~ last 6 digit of VIN is 210827 or later)4. TUNER KIT CONTENTS:This can be a difficult and time consuming installation that may require the skill of the master technician who isfamiliar with electronics installation. Contact your regional DTS for additional information on installation support.Tuner unit, antenna, and antenna splitter must be same brand, XM or SIRIUSThis is a universal installation kit so all parts may not be used.Re-installation of satellite radio antenna to be performed by an authorized dealer only.In the event the satellite radio antenna or antenna splitter needs to be re-installed, do not use the originalmounting tape. Order the low profile antenna adhesive tape kit:999U9-VQ010In the event the satellite radio antenna needs to be replaced, order the appropriate Satellite Antenna Kit.XM LPA 11’ service kit 999U9-VQ012SIRIUS LPA 11’ service kit 999U9-VQ013XM splitter 999U9-VQ004SIRIUS splitter 999U9-VQ005! CAUTIONNo. Parts Qty1 Tuner 12 Black Tape 23 Velcro Tape (hook) 24 Velcro Tape (loop) 25 Spacer 16 Bracket 27 M4 Screw 48 5mm Tapping Screw 49 Ground Cable 110 6mm Tapping Screw 111 Sponge Tape 1412 Edge Protector 113 Clear Tape 414 Corrugated Tube 115 Cable Tie 416 Butyl Gum 217 Cable Clamp 4Parts View2 of 12 284-9613-20-L0 04/22/04G35 (2D)1. Phillips screw driver2. Clip remover3. Electrical tape4. Tape measure5. Die grinder with cutoff wheel(wheel no larger than 3” diameter)6. Masking tape7. Bitumen wax (999MP-9G001P)or equivalent8. 50/50-alcohol/water solution9. PGF stick for antenna cablerouting10. Drill with 4mm (5/32”) bitequipped with 1cm (1/2”) stop6. STANDARD CONNECTION METHOD5. TOOL & MATERIAL REQUIRED:15~20mm2~3mmSatellite TunerUnitSatelliteAntennaA16A16Ground CableGroundIf the tuner unit is installed using the bracketand the bracket is screwed onto the metal partof the car body where a ground can be made,it is not necessary to use the ground cable.CurryGreenVehicle HarnessAntenna Splitter3 of 12 284-9613-20-L0 04/22/04G35 (2D)Satellite antennaTuner unitAntenna splitter(2) Apply parking brake.(3) Make sure that the shift lever is engaged in the “P” position.(4) Open the trunk lid.(5) Open the windows completely.(6) Disconnect the battery negative terminal to prevent short circuits during installation.8. VEHICLE PREPARATION1 2 3 4 5 6 7AMAM2FM1FM2FM3ESN number located on tuner box7. INSTALLATION OUTLINE(1) Record the customer radio preset.Using PGF stick to confirm no excessive amount of sealant under rear window molding at the area where antenna cableswill be tucked into. Do not proceed to install satellite radio if excessive amount of sealant exists.! CAUTIONBefore disconnecting the battery negative terminal, lower the windows completely.! CAUTION4 of 12 284-9613-20-L0 04/22/04G35 (2D)figure 1(7) Remove the following trunk interior trim parts as shown in figure 1.1. Trunk floor carpet.2. Trunk floor board (center)3. Spare tire.4. Trunk rear plate.5. Trunk rear finisher (end).6. Rear wheelhouse finisher (left).7. Trunk rear finisher (upper).8. Trunk floor spacer (left).5 of 12 284-9613-20-L0 04/22/04G35 (2D)PGF stick Rear windowMetalwindow framePGF stickPGF stickfigure 2figure 3figure 4Cut a notch3mm deep and15mm wide235mm(1) Clean top edge of rear window glass and the roofwhere the antenna will be installed with 50/50 alcohol/water solution. (figure 3)(2) Cut the antenna tail 2~3mm off. figure 4(3) Place antenna roughly at center of rear roof.(4) Route antenna cable along top edge of rear windowglass to left upper corner of glass. Leave cable free;will be covered later.(5) Remove rear end of left drip rail cover.(6) Wet the rear window rubber molding, under whichantenna cable run, with soapy water. Insert PGFstick under the rubber molding, between rubbermolding and metal window frame. Then move it bothvertically and horizontally along the rubber moldingto wet all the part of it.9. ANTENNA INSTALLATION9-1. Notch cutting9-2. Antenna installation(3) Remove burrs or sharp edges from the notch. Leavecables free; will be covered by feeder cover later.(4) Apply Rust-proof to cut surface.Do not damage vehicle parts during notch cuttingprocedure.Protect window and trim with fender cover or similar.! CAUTIONDo not touch or contaminate the cleaned roof or theadhesive tape on the antenna to prevent the adhesionstrength from being reduced.! CAUTION(1) Remove the weather strip at left front of trunk.(2) Cut a notch on gutter lip with die grinder, 235mmaway from left trunk sheet metal. (figure 2)Do not damage antenna cable.! CAUTION6 of 12 284-9613-20-L0 04/22/04G35 (2D)figure 5Insert the PGF stick under the rubber molding.Twist it to make room under the rubber molding.Place the antenna cable, while making a loop atthe end of the cable, under the rubber molding.PRIMER Handling procedures & precautionsInflammable. Mixture of humidity and water prohibited.Precautionary informationThe primer is volatile. It may be harmful and poisonous if inhaled.To prevent accidents, please observe the following precautions,(1) Avoid breathing vapors, mists or spray. Use with an appropriate local exhaust ventilation. If the exhaust ventilationis not adequate, use an appropriate respiratory protection, i.e. an air respirator or a gas mask, etc.(2) Avoid eye or skin contact. Wear unvented goggles or appropriate gloves.(3) Wash exposed areas thoroughly with a soap and water, and gargle the throat after using it.(4) Do not mix something else, e.g. water, etc.(5) Keep away from heat, sparks, open flame and other sources of ignition.(6) Ground containers securely when transferring contents. Wear low static or properly grounded shoes.(7) Contents may be under pressure, open carefully.(8) Store in a cool place to prevent a solvent evaporation. Use up at one time.Suggested first aid(1) Skin contact: Immediately flush skin with large amounts of water. Remove contaminated clothing. If irritationpersists, call a physician. Wash contaminated clothing before reuse.(2) Eye contact: Immediately flush eyes with large amounts of water at least 15 minutes. Get immediate medicalattention.(3) Inhalation: Remove person to fresh air. If not breathing, give artificial respiration. If breathing is difficult, getimmediate medical attention.(4) If swallowed: Do not induce vomiting. Drink two glasses of water. Call physician.Primer coating* Coat the primer uniformly to the part surface.* The amount of primer coating varies depending on the material and surface condition.* Apply the primer before the non-woven cloth dries. The primer cannot be used after the non-woven cloth dries.Drying time* In general, the recommended drying time under standard conditions (23ºC and 65% relative humidity) is10 minutes to 3 hours. The primer should be dried at least 10 minutes under the standard conditions.* Drying time varies depending on the ambient temperature and humidity, as well as the amount of coating.* Avoid dusts, a contamination and water, etc.* If the primer drying time passes over 24 hours, please re-apply the primer again.In case of fire* Extinguish the fire with a media of a carbon dioxide or a dry chemical.(8) Clean the upper end of rear window glass with50/50 alcohol/water solution.(9) Apply primer to about a 10 mm width strip on upperend of rear window glass. (figure 5)(7) Use a PGF stick to route the antenna cabledown the left hand side of rear window glass whiletucking the antenna cable under the rubbermolding.NOTEPrimer is highly flammable.Primer is harmful by inhalation.Primer is irritating to eyes.Read handling procedures & precautions for details.! WARNING7 of 12 284-9613-20-L0 04/22/04G35 (2D)CoverRoof Peel the protectorRear window glassR(Side roof line)L(Side roof line)Difference between L & R must be less or equal 2mmfigure 6figure 6-1figure 7(10) Place cable cover on top edge of rear window.Center the cover by checking both ends to haveequal distance to drip rail. Apply masking tape tohold the cover. (figure 6)(11) Align antenna tail with the center notch of thecover.(12) Peel off two inches of tape protector on both leftand right sides starting from the end. Place thecover on the glass close to the roof ‘s edge. Holdthe left tab. Peel the rest of the tape protector inchby inch until you reach the center. Apply smootheven pressure to the cover.(13) Check to confirm the difference of the distancefrom side roof line to left and right ends of thecover is within 2mm. (fig. 6-1)(14) Cut the shape of the antenna and 2 square holesout of the template.(15) Place paper template on the glass and the antenna.Center the template with the centerline on theglass. Hold the template by masking tape.(figure 7)(16) Center the antenna with the template.In case of ambient temperature below 20ºC (70ºF), it isrequired to warm the tape and mounting surface with aheater to minimum of 20ºC (70ºF).! CAUTIONProperly align rear end of antenna tail to flush with rearedge of the roof.! CAUTIONKeep the vehicle inside at least for an hour after applyingadhesive tapes.Avoid works imposing pressure on the adhered areasincluding car wash within 48 hours.! CAUTIONBe sure to install the cover tightly against the roofedge correctly. Once installed, the cover can NOT bemoved.Do not pull the cover; the cover may stretch.When install from ends toward cover’s center, ensurethe cover is flat.! CAUTION8 of 12 284-9613-20-L0 04/22/04G35 (2D)figure 8figure 9(17) Peel off 1” tape protector from rear of antenna tail.(figure 8)(18) Align notch of antenna tail to edge of roof and laydown tail. Pull off tape protector from antenna tailcompletely.(19) Peel off tape protector from antenna. Place theantenna and apply 20 lbs. of downward force for20 seconds while rocking hand back and forthacross the top of antenna to assure proper adhesion.(figure 9)(20) With hand pressure, apply downward force to thefull length of the tail to assure proper adhesion.(21) Remove the template.(22) Clean the left bottom of the rear glass windowwhere cable cover will be installed with 50/50alcohol/water solution.(23) Attach the cable cover (short) to the antenna cableat the left bottom of the rear glass window.Apply 18 black tape over antenna cable.(figure 10-1)During antenna mounting process, make sure rubberdust seal “flares” outward while downward force isapplied.! CAUTIONDo not contaminate cleaned surface before applicationof clear tape in step (30).! CAUTIONKeep the vehicle inside at least for an hour afterapplying adhesive tapes.Avoid works imposing pressure on the adheredareas including car wash within 48 hours.! CAUTIONThe following steps 24 to 31 are critical to water leaktherefore must be followed strictly.(24) Apply 13 clear tape to the left underside of thegutter to prevent abrasion. (figure 10-3)(25) Attach the 12 edge protector over the notch.(26) Use alcohol wipe included in the kit to clean thesurrounding area before application of clear tape.(27) Route the antenna cable over the edge protector.Make sure antenna cable is seated in the channel ofthe edge protector.! CAUTION9 of 12 284-9613-20-L0 04/22/04G35 (2D)figure 10-1figure 10-3 figure 10-2(28) Position the clear tape above the notch withoutpeeling off the liner to estimate the correct positionfor the small amount of butyl gum.(29) Before applying the clear tape, apply a smallamount of butyl gum to bottom side of antennacable to hold antenna cable at the radius cornerwhere antenna cable will enter the clear tape.(30) Do not peel off the entire clear tape protector. Pullthe clear tape protector back 10mm (3/8”). Thenapply 10 mm clear tape to the horizontal flat sur-face of the gutter. Then slowly massage the cleartape with a PGF stick till you have reached thecorners. Make sure that the tape does not wrinkle.Apply the same technique to the vertical surface.Then fold the tape over and apply the techniqueonce more. This should leave a smooth surface onall three sides. (figures 10-2 & 10-3)10 of 12 284-9613-20-L0 04/22/04G35 (2D)In order to stop water from entering the trunkthrough the clear tape, the clear tape must havecomplete (100%) wet out 5 - 10mm (1/4” - 3/8”) onall three sides of peripheral boundary and no wrinkle.(figure 10-2)Ensure antenna cable is entering the clear tape atthe radius corner.(31) Apply butyl gum at both ends of the clear tape.The butyl gum should fit into both corners to coverthe antenna cable and the opposite end of theclear tape. (figure 10-2)16! CAUTIONButyl gum must be placed across cable for goodwater seal.! CAUTIONIn case of ambient temperature below 20ºC (70ºF), itis required to warm the tape and mounting surfacewith a heater to minimum of 20ºC (70ºF).! CAUTION10. TUNER INSTALLATIONSpacerN-BUS cableFloor panel5 SpacerTrunk panelRemove tapeFront20mm100mm(1) Remove the tape to release N-BUS cable.figure 11-1figure 1111 of 12 284-9613-20-L0 04/22/04G35 (2D)9 Ground cable1 TunerAmp. mounting screwEarth point10~20mm90~100mm9 Groundcable7 M4 screwAntenna cableAntennasplitterN-BUS cableFrontAntenna cable2 Black tape100mmAntenna cableSeat back releaseleverSpongetape(6) Connect the 9 ground cable to the tuner using the7 M4 screw. (fig. 12-1)(7) Connect the ground cable to the vehicle groundscrew.(8) Clean the back of the tuner with 50/50 alcohol/water solution.(9) Attach tuner to the top of stacked spacers.(2) Clean trunk floor panel with 50/50 alcohol/watersolution where the tuner is to be attached.(3) Cut spacer to 10 pieces.(4) Stack up 5 pieces spacer together. (figure 11-1)(5) Attach spacer to the floor panel where the tuner willbe installed.figure 12-2figure 12figure 12-112
Telcoman
