Satellite Radio Install
nuge1ado
I have searched for answers on this forum, but no luck.
So, I am starting a new topic. I have an 04 M45. My VIN # indicates that my car is pre-wired for satellite radio. I have looked for the harness in my trunk, but no luck. Does anyone have any idea where this harness is?
lfj2025
Car: 2003 Infiniti M45 Black on Black & 2000 Mustang GT convert
Behind the driver's side quarter panel. Once you pull the panel off in the trunk you'll see all kinds of goodies! There are pictures posted somewhere on this form.
bayou-M
When you remove the trunk liner on the driver's side you'll see a couple series of tape-wrapped wires near the top of the trunk. There is a black plastic bag (more like a plastic sheet actually) that encases the plugs. Unwrap the electrical tape around this sheet and you'll find the two white plugs for your sat radio. They are plugged together with a connector plug in order to make the CD player work if there is no sat radio hooked up. You'll plug both those plugs into your sat radio receiver.
