wshymas »
https://forums.nicoclub.com/wshymas-u271332.html
Sun Jan 29, 2017 8:17 pm
Hello all,
I am a new owner of a 2006 M35x. the car has nav 14 speaker bose and sat radio (found in the trunk all wires/antenna connected).I have searched the forum and google and still need help.
The problem is that when I press the radio button to get to the sat setting all the I get is "acquiring" on the display.
I have removed the tuner to get the sirius ID number then reinstalled (added m35 to my sirius subscription). I have called xm/sirius and gone through the troubleshooting steps and was told to take it to a dealer (closest one is 2.5 hours away). I also connected a different antenna to the tuner to check for a bad roof/fin antenna. When the antenna is disconnected the display reads antenna error.
What else do I need to check?
I there a place I can send my tuner to to have it checked and/or repared?
If I replace the tuner should I go with the same P/N or can I use any infiniti tuner?
Thanks for the help.
