Bluefire »
https://forums.nicoclub.com/bluefire-u7784.html
Sat Feb 03, 2007 8:12 am
+1 for sard or nismo and aeromotive. for low hp, nismo is fast, simple, cheapest fpr. Direct bolt on makes it a 5 minute install.
Sard is better for higher hp settings. I have used the sard regulator on 3 or so 400-500 hp sr's and they work beautifully. As for comment about more connections to leak. This is true, but not a problem at all unless you don't know how to properly tighten npt or an fitting. Sard also has hose nipples that allow you to use rubber hose, if you don't feel like making steel braided fuel lines.
Aeromotive is all around a good, and is capable of the highest hp. They have styles to allow for -6 -8 -10 hose. I haven't used one personally but have heard great things from friends
-Bluefire
