sard fpr......installation tips
rocwyld06
Car: tuning, sports, cars, tv, etc
has any installed a sard fpr? need help installing. my instructions are completely in japanese.
180fan
Car: 89 fastback
mount on the shock tower, get the nismo adapter for the fuel line for like 60 bucks at phase2 or ht then run some fuel line to connect, get a long vac line for the vac signal to the fpr. make sure you get the orientation right. option for nismo adapter is to get a tap, make some threads on the inside of your fuel rail and then get the nipple off the sard and install in both the fuel rail and the fpr AN fittings and then run some high pressure fuel line with the appropriate AN fittings on their ends.
