SARD 850CC INSTALLED Gas everywhere
afmafia
i used to have a set of sard 550cc and they worked fine then i upgraded to some dard 850cc all that came in the kit was the injecters and gold spacers . do i need to install the collars from my 550cc so they wont leak anymore. also when u buy sard 850cc injecter what is included >>??? any info is appreshated thanks jon
afmafia
isnt the new 850c injecter supposed to have new o rings ??? cause i didnt add any more
afmafia
any ideas?
BaliLover
My Tomei injectors didn't come with Orings so the sards may not either. As for just dropping new injectors in, if your ECU isn't tuned for them the car isn't going to run, its just going to dump a TON of fuel and flood out.
ca18det_boy
yes you need the collars
afmafia
cadetbot from what i was told by enjuki racing is that 550sards come with collars and plugs 850 cc come with gold rings and plugs also u need to change the oring with ka/z32 o rings i didnt change any o rings so i guess ill do that tomm
spider_slayer
Car: S14 240SX
S13 240SX
if you reused your o-rings they could have been slightly damaged when taking out/ installing your new injectors.
Rookieca18det
Car: 93 hatchback (ca18det)
I would replace the o-rings if you reused them. I've always heard that you should replace your o-rings anytime you remove your injectors. Good luck
-richard
luv2spedup
Car: 89 silvia
where can u ge adapter or collars for to mount 880cc injectors
ca18det_boy
with whoever makes the injectors
