T-rev »
https://forums.nicoclub.com/t-rev-u68340.html
Wed Sep 12, 2007 5:48 pm
When I installed my sandwich plate, I had horrid oil leaks. I had the big bolt tightened down enough, but it was leaking around the sensors. Make sure you get those things tight! I was worried about stripping out the threads since it was only an ebay special.
I used teflon tape on the 2nd time around.But this depends on your sensors. They may be grounded through the engine, so you cannot use teflon tape, you will have to use a liquid thread sealant.
I found the sandwich plate made the oil filter easier to get off by hand, since it makes it stick out by an extra inch or so.
