Sandwhichplates/ Relocation units
mattleegee
Car: s13+19 corolla
I want to get some gauges plugged inGreddy relocation kit has a couple spots for that
But is there a cheaper way? I really dont want to relocate the oil filter and spend a couple hundred to do it
Can we use a sandwhich plate and where to get one?http://prosportgauges.com/oil-....aspx
Any of these work?rb25det
Ideas? Thanks
johnny butt
Car: 1993 240sx Convertible
How many gauges and what kind?
If you want oil pressure and oil temp. you will need one of those.
Oil pressure, you could get with just the stock oil-filter housing and replacing your sending unit with the OEM sending unit.
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
Are you running an external heat exchanger (cooler) for your oil as well?
Yes?#1 Oil Filter Stud RB#2 GReddy Thermo Sandwich Adapter RB
All you have to do is run lines to your cooler, and you bypass the factory water cooled unit.
No! ISIS Oil-Filter Relocation Kit RB
If you are wanting to use the original tap for the factory oil pressure sender, I have my TunerToyz f/s now also.
Support our sponsors!!! The Prosport is.. ok.. but not thermoelectric (waits until oil is warmed up before introducing cool oil to hot motor) somewhat like passive and active cooling, if you understand that.
