Samsung Note 8 blutetooth audio issue
PeteFiniti
Car: 2012 Infiniti M37X
Greetings -
I recently upgraded my phone from a Samsung note 4 to a Samsung note 8. The issue I am having is that on my 2012 M37 I am unable to play audio through Bluetooth with my Note 8. Every time I slide the "audio" selection over on the phone it stays on for a second or two then slides back to off.
I have tried deleting it from a the car and re-pairing. Rebooting the phone etc etc. Still doesn't let me play audio through the Bluetooth in the car. I can receive phone calls and speak over the Bluetooth with no issue. Just no music. When i had the note 4 paired up to the car I did not have this issue.
Anyone else expireince this ? if so, what did you do to resolve it?
M37xnut
Car: 2012 m37x
I recall you have to select the phone on the car. There is an option to have the phone play both phone calls and media. Default is phone only.
Ilya
M37xnut wrote:
Sat Dec 23, 2017 6:55 am
Yes, I believe this is what's happening to you op.
GMBQ70
Car: 2015 Infiniti Q70 3.7 AWD
Is your phone service through Verizon? Apparently this is a known problem with the iPhone 8 and Verizon, which is why my new iPhone 8 will no longer stream on my my 2015 Q70.
JCesar
I had a note 4 and got a note 8 but don't have that problem. it works great. delete all the connections to your car and connect again selecting audio and calls. same for the phone. it should work
