darkspoon »
https://forums.nicoclub.com/darkspoon-u86733.html
Sun Apr 20, 2008 11:39 am
Alright, from what I can understand I'll try to help..
Brake problem - did you bench bleed your Master Cylinder before putting it on the car? As well, try using a vacuum bleeder VS foot pumping method.
Sputter problem - If its after you just changed your fuel filter, check to make sure all your lines are snug and tight, with no leaks. I had the same problem with my fuel, because of no pressure. As well, did you use a new filter or used? (Hopefully new lol)
