Looneybomber wrote:Sounds like your headunit took a poo. You'll either need to get it fixed, replaced or buy an FM transmitter for your iPod.
I forgot to post that the head unit has an equalizer display, and shows sound then in AUX or CD. So I don't believe the head unit took a poo.
TheKon wrote:Well...first things first...what you want to do is remove the head unit....and grab a chevy wrench. Take the chevy wrench and beat the living snot out of the sony head unit but before you do that try removing the head unit and looking at the harness...this is the harness that goes from the head unit into the factory wiring. Cut the blue wire and the blue and white wire and cross the two. Hyndai Tiberons and many other factory amplified stereos have the same problem. Just cross the two wires and you should be good.
Like I said the head unit is fine. So, what you're telling me is that Tiberons have the same problem of playing the radio fine and cutting out when in another source??? and swapping these two wires would fix it???
