Hi i got myself a mulithchecker too ! But before helping i need to ask you a question.. ? did you have problem starting the car whne your multichecker is pluggued?
mine is giving crank angle sensor fault code when connected BEFORE starting the car... its kinda a pain in the ***..
prior to startthe car i need to
-switch off the 12 volt from the multimeter ...-connect the white plug for the mulitchecker-start the car (but the car is running in limp mode bad idle /2500 rpm MAX)-switch on my multichecker ... and after that my car is working nice... I dont know if its a incompatibility with my UK Pre-cat ECU or my wiring.. anyway
today gonna try what you did and tell you my stat on my engine
