major hesitation if revved heavily in neutral, but the worst hesitation and gasping shows up when 30%+ gas pedal is applied while driving...rb25drag wrote:The air noise coming from your MAF is normal I believe. mine does the same thing. Is you more than 20% throttle at all times? Revving and Driving? That sounds like a Bad MAF or its hooked up wrong.
how can I control it?240z4u wrote:Z32 maf is not acceptable without some way of controlling it.
I know, but I have a wedding coming up in 2 month and I can't afford the 250-300 bucks right now..240z4u wrote:Do you have a wideband? If not, you definitely need one!
here's a pic of my BOV lines when I received the clip. They are still run the same way. it's a HKS bov (stock??) you can see the two lines are y-ed together and I traced it on to the air intake...Carl H wrote:your bov is hooked up wrong, bottom nipple is for boost signal and the top for vaccum, this ensures the bov stays closed even under 'high' boost situations. for most ppl only the top is nessicary.it sounds like you have an ignitor issue, have you tried swapping it out for another?is the ignitor damaged in any way?
I don't think it's leaking....if anything, it's not working like it used to. it doesn't make a sound (except that I can hear it echoing out the MAFS) or release air while revving unless I remove the hose on the back..Darius wrote:Is what you're describing the BOV leaking? Is there black smoke coming out of the tailpipe? It's hard to tell from what you are explaining.
do you mean that a damaged ignitor can cause hesitation and choking that are "fixable" by unplugging the o2 sensor? I know I probably need to replace my ignitor too, but without my o2 sensor plugged up it is running soooo much better that I can get back to some of the other general maintenance before I spend some more big bucks...Carl H wrote:you should have stated you have a cracked ignitior, im willing to bet thats your problem.most of the time when ppl have symptoms like you described it can be traced to a damaged ignitor.
what if it is bad wiring to the o2? That is what I am going to check first before I buy a wideband. could bad wiring (a short somewhere) cause a hectic response that makes it run too lean or rich and end up with hesitation and choking out??Carl H wrote:i find it odd that you seem to have some correlation between unplugging the o2 and it running better.the only thing i can come up with is that with it unplugged it runs richer and since it already has a weak spark it help to keep it going where a lean mixture is harder to perpetuate.
