GBSilviaS15 »
https://forums.nicoclub.com/gbsilvias15-u18015.html
Mon Apr 04, 2005 2:05 pm
It's been about a month and I still haven't figured it out. Again, here are the symptoms:
In 1st gear, it sticks to 1st and makes a screeching/grinding noise until I pull out to neutral AND disengage the clutch.
In reverse is the same.
When shifting to next gear, If I shift and the engine rpm is over 2000 with my clutch still engaged, it'll give me a grinding which eventually goes away - with my clutch engaged.
If I disengage my clutch right away, it'll catch and everything is normal... But you can still feel the grinding when you initially put it into the next gear.
****Now I took it apart last week, and lubricated the throwout bearing (release bearing) because it wasn't lubricated at all. I was not sure if this had to be lubricated or not, therefore I only lubed it a little bit. After we put it back together, it worked fine for a couple days, then it started giving me the grinding into the next gear noise, then eventually the sticky screeching/grinding in 1st and reverse.
I checked the installation, everything is installed properly EXCEPT I didn't check the bearing inside the crankshaft... The pilot bushing.
Now would the pilot bushing be a problem if installed incorrectly? How can that possibly installed incorrectly anyway?
So I've narrowed it down to either the pilot bushing, or a bad throw out bearing? Am I accurate about these? Since all these parts are brand new, I don't see the problem.
What all has to be lubricated in a clutch kit? Does the Pilot bushing?
Thanks for any input!
