Saleen rims on a s13
240r
Car: 91 240sx
I was just looking through rims and stumbled upon some saleen 5 spoke rims and thought they looked nice. I was wondering if they would look and fit ok on my s13 after I do my 5 lug conversion. I am looking at the 17x9 with 5x114 lug pattern and 22mm offset. Tell me what you guys think.
Exar-Kun
Car: 2005 350Z
too wide, too positve an offset for the width... next question.-chet
Checkered-Member
Car: 1998 Nissan Altima (modded)
2003 Audi A6 2.7T (stock)
Exar-Kun wrote:too wide, too positve an offset for the width... next question.-chet
I was just about to say that…with 9” width you can fit like 275’s
BuudWeizErr
They aren't too wide.
But you won't be able to fit them on a stock suspension. You'll probably have to stretch some 235-255's across them, some RUCA's to control camber and maybe even roll the fenders a little bit, but you can make them fit.
I was going to get mustang wheels, but there is a small problem, mustang wheels have a different sized hubcentric ring, so you will have to go to a wheel/tire shop and find/have them make you a new hubcentric ring for the wheels.
Exar-Kun
Car: 2005 350Z
its too wide without using a spacer with the stock mustang offset on any S13, the s14 it should be fine(if just barely).....It's still far too wide for anyone needs, and probably weighs a nice bit, too.-chet
solaris22
they make mustang copys with different hub sizes and wheel widths, I think that's what he was talking about
Nismo_Freak
Car: 89 Nissan 240SX
It's too wide for both the front and rear of an S14... it will rub the fenders.
yeswepromise
roll the fenders ;)
Nismo_Freak
yeswepromise wrote:roll the fenders ;)
Not really going to help much... the car will roll over onto the tire in corners.
whiterps13
Car: white LE hatch
what goes into rolling the fenders? also, 17x9's will fit on an s13, if you get the right offset. ive seen people use like +40, but not +22.
Exar-Kun
Car: 2005 350Z
17x9 +40 fit huh? you may want to check the math on that...I seriously doubt that would clear, even on the rears.
"fit" or "work properly" or "proper fitment" are different things, Im sure I can find a 13" wide wheel and make it "fit" in my car, but that doesnt mean it shoud be done.
goes back to the"just because you CAN, doesn't mean you SHOULD"-chet
