Tanin Auto Electronix is running a sale on NEW 2004 2005 2006 Nissan Quest LCD with Ribbon Flat- Only $59.99 each!!!
Tanin Auto Electronix has exactly what you need to repair your Quest! The 2004, 2005, and 2006 Nissan Quest LCD with bonded ribbon cable. Fixes common pixelation and other fading display screen issues. No special tools required, just snap into place. Installation instructions are included.
If you do not follow the video exactly, especially the part where you gently loop the ribbon through the board, the display will not work. We will not be able to warranty or replace a physically damaged LCD. 100% of these LCD's are tested and work before they are shipped to you. If they do not work after you install them there is a problem with your circuit board or you did not install the ribbon correctly. There are no other possibilities.
Picture of final installation: http://taninauto.com/quest/quest.jpg
Video: https://youtu.be/EbsVn7-TjLc
We also offer a higher quality version of this LCD. The ribbon is different and bonded in a more durable fashion. This higher quality LCD is suitable for very hot, dry climates such as Arizona where the LCD ribbon glue can literally melt off of the standard glass LCD.
Contact us with any questions~
