yeah ill probably try that then, i had told the guy at firestone to max out my top camber plates then adjust the rest of the camber as needed from the lca, he didnt listen to me, and im pretty sure that messed up the sai, i have a feeling that it is the sai that is responcible for the turning back since when the struts are nearly vert now it like almost completely went away, so im gonna put them back all the way in and stand there and watch them adjust it from the lca
i had really needed this answered for suree since i needed to know which controls that aspect so i can better dial it in, so i guess caster = straight line tracking and sai = countersteering so ill adjust my specs accordingly
since firestone isnt a performance alignment shop its hard to get the desired spec's you want, i got to learn it all and micromanage the hell out of them
but thanks for the 7 caster spec and i will probably dial my camber back down as well to 3 or 2.5 again ill probably have them set it to that and hopefully my tie rod wont hit the lca i took out the blocker plates so that would help a bit
i already dont have a front sway bar and im running a stock rear
thanks for the info
