Beancooker »
https://forums.nicoclub.com/beancooker-u42602.html
Thu Feb 22, 2007 4:19 pm
Never had this problem... Do you lean on the door, or use it to help yourself into or out of the car? I don't think there is an easy adjustment, but you can adjust it by loosening (sp?) the hinges, and adjusting them. You will need a pneumatic driver to loosen and tighten the hinges, and the doors are heavy and very difficult to adjust. You can also have a local body shop do it. Should cost about $100.
