94_240sx »
https://forums.nicoclub.com/94-240sx-u26401.html
Mon May 15, 2006 3:51 pm
Yes, if you remove the bumper, you can realign it. There are 2 big bolts in the trunk, one big bolt right above tail pipes and small bolts on each side(4 each IIRC). Bumper cover is attached to the reinforcement with several small bolts, so you can just loosen them and line up the bumper cover easily. You might have to make holes bigger, so you can move the bumper cover further up. You don't need FSM. It's pretty straight forward process.
Things to be careful... You don't have much space for the bottom bolt on both side inside of trunk, so it'll be little tough if your hand is big, but just turn the wrench little by little and evetually it'll come out. Bumper itself is pretty heavy, so make sure to put some cardboard and blanket right below the bumper when you work on it. If you drop it, it'll be messed up big time. I mean paint. Wire is attached to license plate bulbs, so don't forget to disconnect it before you put the bumper on the ground. It's little short. To make it line up perfectly, you might have to attach and remove the bumper several times. Just be patient and you will be happy at the end. I hope this helps...
