sprocket »
https://forums.nicoclub.com/sprocket-u136001.html
Tue Oct 24, 2017 6:53 pm
hercules130, there are two different switches depending on the features you have n your 2017 Rogue.
The switch with a speaker icon on the top right is to temporarily turn off blind spot warning (BSW). This is a passive system that doesn't intervene, it just aids by warning you.
The switch without a speaker icon on the top right is to turn on Lane Departure Prevention (LDP). This is an active system that will actually intervene and assist to correct your course, so you need to turn it on when you want to use it.it is default off since they want to make sure you enable this active system when you see fit.
Hope this helps.
