IvanAtSPRacing »
https://forums.nicoclub.com/ivanatspracing-u15633.html
Sun May 02, 2004 7:02 pm
The HKS racing BOV is also a pop off valve. There are two nipples on it. If you run manifold vacuum to the top nipple it works as a BOV. If you run manifold vacuum to the bottom nipple, it works as a POV. If you run both, then it will work as both a BOV and POV. They sell it with different spring pressures for different POV ratings.
I hope this helps
IvanPhatKA-T.com
