aither »
https://forums.nicoclub.com/aither-u7317.html
Fri Oct 31, 2003 7:21 am
Grant: Thanks a lot for your reply. It's cool to be able to get a propt, strait answer to my question! Now I know what to be careful about in the future.Also, to everyone else, I was amused by the posts, but I believe there is a reason why one would want stretched tires to aid drifting. From what I can tell, it gives the tire a much more rigid, "stance," on the wheel, with much less flex than a normal set up. If you combine this with the right tire pressure, you get a tire that is very easy to push past its limit of adhesion, because it will have a much lower slip angle. Anyways, I was just wanting to explain where I was coming from (it's not from reading a mag and doing what looks cool). I'm thinking about what's ideal for a certain function, not what can I get at the tire store with the $20 in my pocket.
