elwesso wrote: I would that think that if JWT(Infiniti) recommends it there, thats PROBABLY the best place... not to say to anyone that a good design cant be improved!
If I understand him correctly, Dennis states that spraying into the air box is your best chance for equal dispersion, as well as assistance from the MAF reading colder temps & adding slightly more fuel for denser air based on it's temp readings. (good)Q45tech wrote:Why many spray into air box to let MAF add what it can...........my point was if the nitrous doesn't mix well the MAF might see -70F -130F and crack the sensor. In Front of oem air filter might be safer. On a humid cool day you might get ICE.
Plenum being the dead center of the spider's body, a better chance than you'd have any other way. In other words, you best chance at that range is still not a viable location, needless to say you're not even at the center of the plenum, you're diagonal from #8 cylinder.DAEDALUS wrote:The air is flowing in from one end, supplying all the cylinders. N2O supplants some of the air, not all of it. You place a supply in the center of the plenum and it's almost guaranteed you won't get an even distribution across the 8 cylinders.
Would there be a decrease in HP or TQ from the N2O shot if you spray into the Air box? I mean, isn't there a point at which the "nozzle" is too far away from the TB?HeavyDuty wrote:If I understand him correctly, Dennis states that spraying into the air box is your best chance for equal dispersion, as well as assistance from the MAF reading colder temps & adding slightly more fuel for denser air based on it's temp readings. (good)
Good question. IMHO, possibly. I've not mounted a nozzle in an air box, but if it were to afford me better dispersion & a less violent introduction, I would consider trying it.PoorManQ45 wrote:Would there be a decrease in HP or TQ from the N2O shot if you spray into the Air box? I mean, isn't there a point at which the "nozzle" is too far away from the TB?
drftard wrote:seems this post is pretty much dead & old but my Q came with a license plate displaying VH45DEN i understand the 1st parts since its the engine name... im pretty sure... and the N im scared is for what most people would assume thats why i have stumbled upon this thread... most of the people posting here already know alot about it & i have no idea... the reason im asking is b/c it seems my car has been owned by a person on this forum in the past & so i'm wondering if my car has been acting up is it due to the extensive miles (230k) & mods i don't understand (ecu from NICO) or maybe the NoS that has been used on the car... thanks... a reply would be much appreciated...
HAHAH, yo! I've replied to almost all of your posts.drftard wrote:seems this post is pretty much dead & old but my Q came with a license plate displaying VH45DEN i understand the 1st parts since its the engine name... im pretty sure... and the N im scared is for what most people would assume thats why i have stumbled upon this thread... most of the people posting here already know alot about it & i have no idea... the reason im asking is b/c it seems my car has been owned by a person on this forum in the past & so i'm wondering if my car has been acting up is it due to the extensive miles (230k) & mods i don't understand (ecu from NICO) or maybe the NoS that has been used on the car... thanks... a reply would be much appreciated...
I actually talked to some NGK engineers either at PRI or the Detroit Auto Show and they said that there is no reason why you should not be able to run their platinum plugs with nitrous. However, I have heard that F-body owners always take out their Bosch platinum plugs before running nitrous. I do believe that the increased pressure can cause the tips to dislodge with some platinum plugs.HeavyDuty wrote:
According to one of the n2o manufacturers' tech line, the violent reaction of nitrous can dislodge the platinum biscuit. Beyond that, I've also heard of preignition issues, popping or backfiring. Also hearsay has it that a copper plug might fail quicker in the event of a catastrophic fuel failure. To be honest, I have asked many many people about this & had so many different answers you wouldn't believe it. I talked to NGK tech line & they confirmed in their experience, Irids are ok, plats are not.
